Local Storage without service plan?
- 2
Just got outfitted with Arlo: Pro3, Doorbell, Baby Mon...the works. I've researched the monthly plans, which are affordable, but I also read that local storage can still be used if a plan is not utilized. However, I've also read here in the community that you actually can only store locally WITH a plan and as a backup. I need some clarification on this. I've attached the verbiage from Arlo below and it seems pretty clear.
@Chemic101 wrote:
No one has given a good explanation to local sd card storage with out subscription.
You mean this?
What is Direct Storage Access and how do I use it?
It doesn't work for you?
@Chemic101 wrote:
Then how to view it from outside your local network.
Maybe that's your problem.
If you are having difficulties with that, tell people what they are. Maybe someone can then help.
Just another user
What a waste of time and money.
Just came to the realization that the direct storage option does not work without a cloud subscription.
I was able to access both direct storage library and cloud storage library when my subscription was active. As soon as I cancelled my subscription I no longer was able to access the direct storage library.
The drop down filter at the top that allows you to select between cloud storage and your local storage disappeared. Which means you are defaulted to the cloud storage with no option to change it.
I have uninstalled the app, rebooted the phone. I tried this on an Android device and iPhone device with the exact same result. No access to direct storage through the app when you no longer have an active subscription.
I wish Arlo would just say this instead of beating around the bush and say offline storage is only available with a subscription. Personally I do not want to pay for a cloud subscription when I only want to use the direct storage but it looks like Arlo does not want to make this option available.
Arlo is a good product and does what I need except for the fact that they force you to a subscription when one is not required. Now I will package up my Arlo and return it to Costco and look for another product.
That's not correct. But direct storage is broken on Android at the moment - there was a bug introduced about a week ago (3.5.1, released on 20 July)
Not correct. I have no service plan and can access the storage on my external hard drive using an iPad, iPhone, and Chromebook. I have heard there is a recent glitch, maybe that has something to do with your issue.
I hope that's the case. I was not on 3.5.1 when I noticed this issue but I updated my android app of Arlo anyway but still the recording doesn't show up.
One thing as highlighted by other community member, it does record on flash drive as the used space keeps going high but can't see those recorded clips from Apps. Currently I am in conversation with their support, will update what they have to say!
I am on Android 3.5.1, did you guys received any new update?
I got 3.5.2 yesterday.
Dated 2021-07-27
Well, it would be if someone hadn't used the insane US dating convention of 07/27/21.
Clear as mud. Confuses the rest of the world.
Just another user
The issue persists even on 3.5.2, clips are recorded on the hard drive but doesn't show up on App. Only get the notifications.
Works here. But I did have to reconfigure the settings for local storage.
This has always been a flaky feature.
Just another user
@michaelkenward wrote:I got 3.5.2 yesterday.
Dated 2021-07-27
Not sure what is confusing. I understand the other way around. Same numbers.
When is 12/07/2021?
In the rest of the world it is 12 July, not 7 December.
Try sorting a column on the US convention.
Just another user
This is a reply to an old post, however, since I didn't see the actual solution presented I'll add my two cents in case some in the future needs it.
In order to record locally, you need to setup your SmartHub first before your cameras. After the SmartHub is set up, you can add your cameras, and can then choose a connection method-- SmartHub or Cloud. SmartHub pairs the cameras to itself, Cloud requires you to pair the camera via a QR Code.
When I setup my cameras initially, I paired them to the cloud, as a result, I was not able to store locally (unless I downloaded the cloud video). I had to remove them from the app and re-add. I have the Arlo Pro 4 camera set from Costco which came with the 4540 BaseStation.
-S
Hi everyone, I just stumbled on this thread regarding subscription with Arlo and Local storage.
I have two Arlo Pro 3 Floodlight cameras and two Arlo Essential spotlight cameras all attached wirelessly to my Arlo SMART HUB VMB4540. I had a monthly subscription with Arlo at $8.99 per month, but once I got the SMART HUB and tested it for local storage, I cancelled my subscription with Arlo. My SMART HUB has a 1TB external hard drive attached to it in place of a USB stick and all appears to be working fine. I can view my records directly from the library in my app on any iphone or ipad that is connected to my devices.
Save myself $8.99 per month, and unlikely going to fill up the 1TB anytime soon.
By the way I can control and view my cameras anywhere in the world, as long as I have and internet connection.
Hope that helps some of you.
Sorry to butt in on this thread.
- 2
