Is there a way to download 30 days of recordings at once?
I see I can download 1 day by selecting all but I would like to be able to select all recordings in the month before contract starts dropping them.
Thank You
cloud storage, maybe. local storage, probably not but you can pull the drive and view it from a workstation.
Try logging in to my.arlo.com from your workstation, you should be able download from the site.
I have tried from my workstation but I can only view 1 day at a time so I can only select a maximum of that day of videos. I would have to repeat this 30 times but would like to do it in one step to save time.
Thank You
Have you tried to set up local storage even as backup. The recordings will be there until you run out of room on USB drive regardless of the cloud recordings being removed after 30 days.
https://kb.arlo.com/000062337/What-is-Direct-Storage-Access-and-how-do-I-use-it
Ah, silly me. You're right. Was thinking the other way around.
