  • 2095 Views
MvZ51
I want to add a Arlo pro 3 Or Arlo pro 4 to my set of Arlo Pro 2 camera’s. Is it possible to connect the pro 3 of pro 4 to the base station of the Arlo Pro 2 ?
Yes... it would work.
read  https://kb.arlo.com/000062253/Is-Arlo-Pro-3-backwards-compatible-with-my-existing-Arlo-system
keep in mind that with the newer cameras, you may be require to have a subscription after trial date
It depends on the base model.  If you have a VMB4000 or newer, then yes.  Otherwise, no.
There is more information here: https://kb.arlo.com/000062284/What-is-the-difference-between-each-Arlo-SmartHub-and-base-station
MvZ51
  • 2096 Views
