Responder
  • 10 respuestas
  • 10849 vistas
  • 0 kudos
  • 3 en conversación
jpeinado
Hola buenas tardes:
me gustaría saber si tenéis alguna nota técnica donde se explique algo acerca de la configuración de las cuentas de invitado
Saludos
gracias
jpeinado
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
jpeinado
Good morning:
First of all, thank you very much @StephenB for your fast answer. This is what I wanted to know.
By the way I am curious about the recommendation of accepting the invitation on a PC (and not on a mobile device)
Best regards
peinado
Ver la solución en mensaje original publicado
10 RESPUESTAS 10
https://kb.arlo.com/000039122/How-do-I-add-friends-to-my-Arlo-account
https://kb.arlo.com/1103229/What-privileges-do-my-friends-have-when-I-grant-them-access-rights-in-my...
Also, I recommend accepting the invitation on a PC (and not on a mobile device).
jpeinado
Good morning:
Best regards
peinado
A lot of people who accept the invitation on their phone report problems here - the invite isn't actually accepted, so they don't see the cameras in the app.
This doesn't happen when people accept on the PC.
jpeinado
Hi again @StephenB :
but anyway they must register an account and login in the phone. Am I right?
could you explain me how to do, the full process? I,e
1) registering an account in phone (iOS in my son’s phone)
2) accepting the app in computer…?
am I right?
Best regards.
jpeinado
Yes.
  1. Install the Arlo app on the iPhone
  2. Create an Arlo account on the iPhone
  3. Accept the invite on the PC (which will open a browser window)
Been a while, but I think what happens next is that you'll need to log in (in the browser) using your son's credentials.  There should be a login authentication on his phone, which you will need to accept.  Then the process should complete.
jpeinado
Thank you very much @StephenB
Best regards
peinado
jpeinado
All ok @StephenB . I got to invite my son’s iPhone.
A last  (silly) question. I suppose, now the geofencing system also includes my son.
The alarm is enabled when me and my son are out, an disabled when me or my son are in. Am I right?
Thank you very much for your good support.
jpeinado
jpeinado
Hi again:
My silly question was not so silly.
I invited yesterday my son's iphone. All worked ok.
He is sleeping now (no camera in his room). A while ago,  I went out my home and my iphone sent me a notification telling me the system is in "absent" mode. What does it means? My son is in home. Is the alarm enabled with geofencing? I am not sure. I disabled manually by avoid sounding
Best regards
jpeinado
jpeinado
I wanted to tell "to avoid sounding". I don't know if I can change an answer..
jpeinado
QuimS
hola, yo lo tengo configurado y funciona muy bien el modo invitados, tengo invitado a camaras + otra homehub y no hay problema.
  • 10 respuestas
  • 10850 vistas
  • 0 kudos
  • 3 en conversación
