I need to speak with a sales person but there is no way to speak to a person. If it is this hard to speak to sales, I may have to ditch the entire system and go with a competitor. Does anyone know the secret to getting to talk to someone at Arlo 3. thanks
Hi Brooke, Not exactly. I was exonerated.hen tech support investigated my case they said I was correct, there is a bug in their system that will not allow me to do ANYTHING related to subscriptions. There were actually two bugs I forget what the other is. I felt better in that at least Im not crazy lol. They switched to a different subscription model wher you pay one price for inlimited cameras so my cameras will automatically transition to that plan after the trial period. I appreciate your follow up and the tech (Kurt?) that assisted me kept his word that he would follow up and he did. TY
They don't make it easy to talk to a human. If you have a current subscription (paid or trial), if you go through the process to add a camera and it fails multiple times, you ultimately see a box that says, Need Help? If you click on that you get choices like On Line Support or some such and something else, maybe Chat. But there's also a choice to TALK with support. If you click that you have to input your phone number, and someone will call you between 6am and 6pm Pacific Time.
I did this right at 6am Pacific time and someone called me within a couple of minutes. The person was pleasant, but ultimately didn't solve my problem (camera that was connected stopped recording and now won't connect). Unfortunately, they were difficult to understand, and after trying to help me for about 15 minutes the phone disconnected, and they didn't call back. There was a case report entered in my account.
@jimmbonz were you able to reach out to a representive?
I was not. I dont even have a phone number to call. This is crazy. Can you provide one? I would like to buy a camera and add it but also take the existing camera off the library
Do you have a single camera subscription now? If you do, you can
- purchase the new camera, and start using it. Keep the existing camera in the account and working for now
- when the trial is about to expire on the new camera, then remove the existing camera from your account
Not sure if the new camera will automatically move into the paid subscription when the trial ends, or if you will have to drag it into the subscription plan using the app.
You could also cancel the current subscription and purchase a new one if you prefer.
If you see "Library" in your app menu, then you can use this guide to reach phone support:
If you see "Feed" and "Dashboard" instead, then you can use this one:
Considering replacing an Essential Outdoor camera with FB1001-100NAS. I currently use the solar panel to charge it. Does the FB1001 accept a solar panel? I want to take the Essential out of the subscription plan and just use it indoors for watching the pets when I am not home. No need to record.
@jimmbonz I have reached out to support regarding your concerns listed above. Support will reach out to you as soon as possible.
The FB1001 can be connected to the Ultra's solar panel (VMA5600), but not the Essential panels. FWIW, I have an extra XL battery and the external charging station, and just swap out the battery as needed.
It can't be used with a screw mount, it comes with its own mount assembly. That looks similar to the "total security mount" (but is not same, and they are not interchangable). The camera itself is similar to the Pro 4 as far as the features go.
You certainly can do that. One obvious way is to cancel the subscription on the Essential, and get a new single-camera subscription for the floodlight when the trial expires.
Ok I was incorrect, I must have a Pro4 model. Would I just swap out the unit and reuse the solar panel?
If your camera has the magnetic connector, you can reuse the panel.
You can confirm the camera model by opening the housing and removing the battery inside. There is a label there.
I want to thank everyone in the community for your support. I was able to eventually speak with ARLO and purchased a Wireless Floodlight. The Rep was able to confirm that the solar panel I have is compatible with the new camera/flood. My Next adventure will be when I move the cameras over to a new network (Google Mesh) and add the new camera for recording subscription. I am not technically proficient.I can get by, barely lol!
When you get it, you can post any questions regarding the set up on here. There is a lot of help within the community and we would be more than happy to assist.
Thanks lol. Already have my first problem. My wireless is 5ghz. I didnt know these only operate on 2.4ghz. Now I have to figure how to fix this lol
Does your internet provide the option for both?
yes my phone is connected to 2.4. but for some reason the camera is not discoverable
its such a simple procedure yet it doesnt work. I get to pairing scan the QR then thats it. i tried 8 feet from the router I also tried other locations with no luck
wait it just got recognized continuing setup
ok its online. Now I just need to terminate recording on the old camera. I assume that is remove device? But that seems overkill. I should just be able to take it off subscription
Are you no longer going to use the device? If so the easiest way would be to just remove the device.
I want to use the device inside my house to check up on my pets. I dont need it to record. I only need to connect to it to view realtime stream
To remove a camera from an Arlo subscription, you can deactivate it in the Arlo Secure app or on the Arlo website:
- Open the Arlo Secure app or log in to your Arlo account at my.arlo.com
- Select Settings > Subscription > Manage Camera
- Tap and hold the three lines to the right of the camera you want to deactivate
- Drag the camera to the Drag a camera here to deactivate field
- Select Continue
You can also remove a device from your Arlo account by following these steps:
- Select Settings > My Devices
- Choose the device you want to remove
- Scroll to the bottom of the page and select Remove Device
- Select Yes to confirm
ok so removing it totally removes it then you have to add in back again. Nor sure if the subscription is affected.
BTW the app steps dont correspond to the steps you provided I dont have those options for some reason lol
The subscription shouldn't be affected. Were you able to remove it from the subscription?
theres no way to know 9at least that I know of) I removed device then added it. I assumed when I added it it comes back without subscription?
