Hi
I can’t get my Arlo app to connect to my wireless night hawk router?
Works here. We need a lot more details. Have you connected the Ethernet cable? Does the router show that the hub has an IP address? Have you tried resetting the hub by holding the reset button until the LED flashes amber?
I have no idea what you are trying to do, so forgive me if these sound like daft questions.
What is this Arlo app? Something on a mobile device? Android? iOS?
Are you trying to connect to the wifi from the Nighthawk router?
Just another user
