Hub wont reconnect
Hub will not reconnect.
Gestion fron solid yellow to blue and 15 secs later to flashing yellow?
Does not see unit when trying to reconnect. Did a unplug, remet, remove, etc.
Is my hub shot?
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support through the Arlo Mobile App by navigating to Settings/System/Support.
