  • 1677 Views
Noobe
When the Front Door triggers the Facing House is suppose to record as well as Front Door. But only the front Door is recording. The spot light comes on the Facing House but it doesn’t send video to the cloud, just video from Front Door? Help...
Mavrrick
Luminary
Luminary
In the mode setup click on the rule that is triggered when motion is found at the front Door. Below where you currently have the Front door setup to record there should be an option to Click "+ Add Device" Click that and setup the action for the Facing house camera
Noobe
I have done it that way. I attached a screenshot with my original post, showing my mode setup. Still no results.
Mavrrick
Luminary
Luminary
Something isn't adding up. Based on the screenshot the only device you have recording by that rule is the facing camera and not the front door camera. The front door camera is not. You needto click on add device and setup a record action for front door.
  • 1678 Views
