How can I increase the range?
If arlo pro 3 has its own wifi network and does not use my other boosted wifi networks how can i increase the range of this network so cameras have sufficient wifi signal to operate properly?
The Pro 3 requires a hub to work so repositioning the hub (perhaps using a WiFi extender to connect the hub to) for a more optimal position for all cameras would usually be the fix. If the area is too widespread, a second hub woulld be needed.
