How can I activate two-factor authentication without a mobile phone
  • 2 Replies
  • 2458 Views
Bette99
I have just received notification about the "solution" to the topics about two-factor authentication. The "solution" is that 2FA will be mandatory starting April 18, 2021.
I have still not received a solution to the case I have opened about how to activate 2FA when you do not have a mobile phone/phone number. Case # 41908659.
Please explain how I will be able to use my Arlo cameras after April 18, when the only way to activate 2FA is to provide a mobile number (and yes, I have tried to just provide a non-mobile number, but that is rejected).
And please do not just say "but you can use email as a backup method". That is obviously only available once 2FA has been activated -  which I cannot do without a mobile phone number...
Bette99
I did finally receive a response from the support team, thank you for the escalation. And after a little back and forth it turns out that Arlo did in fact enable choosing email as the primary 2FA method on activation (no need for a mobile phone). So my issue has been solved.
JessicaP
Hi Bette99,
I've escalated your case to the support team and they should reach out to you after they finish reviewing your case.
Bette99
  • 2 Replies
  • 2458 Views
