I am trying to remotely restart my base station (VMB4540r3). I do not see a reset button under device settings. I know others have posted that the option is there for them for the Arlo Pro 2. Is this remote reset option not available for my base station model? Any help would b appreciated.
If the base is offline, the Restart selection won't be there since there's no communication. A WiFi-enabled switch that the base plugs into would be a cheap way to be able to power cycle the base in this sort of case.
Are you logging in using a granted user account?
