I have around 12 cameras and doorbells. First of all
i get on and it says I have no plan so support had me sign out and sign back in three time. Then I sign back in the last time and no feed and no feed history. This is BS. I’ve been with Arlo a long time. No amount of resetting deleting and Redding cameras has made a difference. I’m am 😡😡😡😡😡😡😡😡
Can you please send me a screenshot of what you are seeing under feed. You can send this via dm, you send a dm by clicking on the envelope icon on the top right of the forum page.If you don't see it, then go into your profile settings and select preferences, then "Private Messenger." Then select "Turn on private messages" if it is turned off.
