I need Jan 4th. It stops on the 5th.
It’s critical I see footage from 1/4/2022
Old/deleted videos can't be recovered. Proactive downloading or use of the local storage capability when using a hub are the only ways to be able to go back.
I appreciate that information.... and my device was supposed to store 30 days before moving forward.
I'm referring to one week ago and can't understand why they're not offered.
Is there a setting that I need to broaden? Can the company access them? It's difficult to get someone from Arlo to address my inquiry so I posted here.
Yes, if you have a subscription it should be more. An older Legacy system like the 3000 base/cameras without a subscription, storage is only 7 days.
@Gloriike wrote:I appreciate that information.... and my device was supposed to store 30 days before moving forward.
Are you sure you don't have any filters on in the library and the cam is Pro3 correct?.
