Disable light during motion
I have a flood light near where my camera is installed, each time there is motion the arlo light comes on and the video is poor.
Is there a way to keep the light from turning on? I've thought about putting tape over it as I wont need it.
Have you tried going into video settings->low light settings in the app or web client, and turning the spotlight off there?
I've made that change and will see how it changes the camera recordings.
