Date/Time no longer visible on recording
My records used to display the date/time but now only a solid (white) bar on top of the screen. Is there a setting that needs changed?
I recently installed the arlo app onto a android phone and see the same problem when rotating the phone .edit.
I decided to go back to using my iPhone instead.
@crclark47 are you on an android or iPhone?
