Constantly offline
I have one camera out of 4 that is constantly offline, or non-responsive. It receives a strong signal, has been rebooted and reset multiple times. Typically, it will work for a day, and then back to not working. It has constant power and is closer than 2 other cameras.
Swap cameras around to see if it's the camera or location.
I tried, but it didn’t work. Thanks for the suggestion!
Not sure what you mean by "didn't work".
After the swap, did the problem
- stay with the camera,
- stay with the location
- or something else?
The problem stayed with the camera.
Ok. Of course that could mean the camera is failing.
But I suggest removing the AC power for a bit, and see if the camera behaves differently.
