  • 5 Replies
  • 1900 Views
po26sox
I have one camera out of 4 that is constantly offline, or non-responsive. It receives a strong signal, has been rebooted and reset multiple times. Typically, it will work for a day, and then back to not working. It has constant power and is closer than 2 other cameras.
5 REPLIES 5
Swap cameras around to see if it's the camera or location.
po26sox
I tried, but it didn’t work.  Thanks for the suggestion!
Not sure what you mean by "didn't work".
After the swap, did the problem
  1. stay with the camera,
  2. stay with the location
  3. or something else?
po26sox
The problem stayed with the camera.
Ok.  Of course that could mean the camera is failing.
But I suggest removing the AC power for a bit, and see if the camera behaves differently.
  • 5 Replies
  • 1900 Views
