  • 8 Replies
  • 3759 Views
Shaneoberry
My arlo constantly changes from schedule to armed and is draining my batteries. Any fix to this?
8 REPLIES 8
Do you have geofencing enabled?
Shaneoberry
Yes. But every other day or so I notice its changed to enabled
Shaneoberry
I realize my mistake. I should have said "it changes from Geo fencing to strictly enabled
Have you turned on the geofencing notifications, so you can confirm that geofencing is properly determining when you leave home or return?
Shaneoberry
Yes. And it works for a little while. Then I start getting notifications of movement and such when I know I shouldn't. So I check what more its in and it turns itself into "armed" and not "Geo fencing"
Putting aside the motion notifications - I am wondering if you are still getting notifications from about geofencing (transitions to home and away).
Do you see "Library" on the main screen?  Or do you see "Dashboard" and "Feed" instead?
Also, are you using an iPhone?  Or Android?
Shaneoberry
I use android and it says library
Ok.  I use iPhone, which is organized a bit differently.
When I go into the general Apple settings for Arlo Secure there is a geofencing notification section:
"Notification Alerts are sent when you enter or leave a location".
Do you see a similar setting?  If so, is it enabled?
  • 8 Replies
  • 3760 Views
