Thanks all! I got it to work by putting the ethernet cable into the router and adding the cameras manually. Again, thanks!
Use the reset button on the hub. Hold it until the LED flashes amber and let it reboot. CHeck the LED behavior to see if it changes. You may need to reboot your router and hub, in that order.
Not sure what's happening but I'd suggest swapping at the store. If you want, use the Contact Support link at the bottom here to see if they can help.
Henka,
When you say you went back to the store and there it work just fine, do you mean you tested it there and didn't experience the issue? If so, this would indicate something on your network is blocking connectivity between the SmartHub and the Arlo cloud.
Hi Henka, who is your home ISP?
I’d recommend factory resetting your router. That will ensure any the settings that may have been changed that are causing your issues are back to factory setting. It is not much work to perform that step.
I'd suggest getting the store to connect and add your hub and waiting for a firmware update if it isn't already updated.
Somewhere on the router is a small sticker with its webpage to log into and it will show the user name and password as well to help get you back up after the reset.
