Has anyone else been having the issue that on iOS the Arlo app logs me out every time I close it, which seems to have the knock on effect that I don’t get any notifications when motion is detected. Any advise on how to keep logged in even when not using the app would be great. I have done all the usual fixes of making sure I have the latest iOS, app etc. Cheers, Will
I'm not seeing this behavior on my iPhone 12 mini, though I am still running OS 14.8
How are you closing it? Swiping up from the bar at the bottom of the app? Or are you doing something else?
@Midmer2503 wrote:
Hi Stephen, I’m just swiping up from the bottom like you would the clear the screen, not fully closing the app by holding the swipe up. Cheers, Will
This was happening before you upgraded to iOS 15?
What iPhone model do you have?
Had this myself. If you go into the iphone settings, scroll down to the Arlo app in the app list and turn on Face ID, which for some reason defaulted to off. Then each time you open the app, face ID instanly logs you in. I had to toggle the use face id setting in the arlo app itself too, off then back on.
FWIW, I also use Face ID. Of course it isn't available on all iPhones - and being logged out also creates issues with geofencing. So this workaround won't work for everyone.
