Can't access recordings!
  • 1366 Views
sarathy33
I updated the software today.  Now it won't let me view the recordings.  At the top it says Library now and not Base Station.  How to fix it?  Please  reply ASAP.  Thx.  Partha.
ShayneS
Oh okay, thanks for letting me know. Keep me updated if you experience an issue again : )
ShayneS
Hi @sarathy33
Which version of the Arlo app are you using? Do you have a screenshot you can share?
sarathy33
Hi:
Thanks for your reply.  I use Arlo 3.  I made it to work.  Just pulled the flash drive out and put it back together.  IT worked.  Thx.  Partha.
ShayneS
  • 1367 Views
