Can Arlo Pro 3 Camera be connected directly to my internet
  • 1 Reply
  • 824 Views
kbost1
i have a smart hub but would like to be able to connect directly to my home wifi because i believe i could get a better signal on the opposite side of the house.
dcfox1
The Pro 3 only connects to the Hub. You could move the Hub to a central location to help the signal. You would need an Ethernet connection or a wifi or Powerline extender with and Ethernet port would work. The newer Pro4 can connect to the hub or your wifi.
  • 1 Reply
  • 825 Views
