Cameras keep disabling
I only have two cameras activated and they both have started saying they are disabled, I turn them on and they go to live then shut right back off.
Are the cameras turned on in the camera settings? This my explain the disabled message.
If you’re finding that the message keeps reappearing then check the settings again to see if they have changed by themselves.
