Cameras constantly need charging
  • 2 Replies
  • 1339 Views
Blown94conv
These cameras need to be charged every 2 to 3 days. Most times when I check them before bed, even though there has been no activity in the yard, the light for the spotlight stays on draining the battery overnight. It’s been happening for the past 2-3 months and no update has solved the issue. Talking to Tech Support is like pulling your teeth with very dull and rusty pliers, at the end of the day you’re just more frustrated and you’ve gotten nowhere.
If the spotlight is constantly on, remove and reconnect the camera - that should stop that behavior. Otherwise, it's a bad camera and you need to work with support to get it replaced.
Blown94conv
I’m going to try over the weekend.
  • 2 Replies
  • 1340 Views
