  • 1 Reply
  • 1072 Views
Locky32
Hi - after charging my cameras battery’s one of the cameras won’t reconnect. The other 2 are connected fine.
The 3rd blue light just comes on and stays on. I’ve disconnect the device and now I can’t re connect it. It just searches continuously and after trying sync Hong and connect manually it still doesn’t work.
Any ideas? The face of the camera is warm for some reason.
If the face is warm and you haven't been holding it, I'd suspect a hardware problem. That would be fixed most quickly by swapping at the store. Otherwise, use the Contact Support link at the bottom here.
  • 1 Reply
  • 1073 Views
