Last week I have only recharged all 3 camera’s. When I’ve placed them back, still no connection. Suddenly after a few days all 3 camera’s tot back the connection. I don’t know hoe this has happend, nut they are working again.
Did you let the batteries totally run out before charging? That causes an issue where you have to plug them in multiple times to get enough charge to properly fully charge.
I know you said you tried the reset methods but what exactly did you do? Did you remove all devices from Settings, My Devices? Did you also try holding the hub's reset button for >10 seconds until the LED flashed amber? If not, do both, let the hub reboot to a solid blue LED and start fresh.
