Camera offline after it's triggered
When a camera gets triggered with a motion, I get a notification. When I try to play that camera, it tries to connect, takes forever, and then fails, and says camera is offline with an ! inside a red circle. I know its not offline bc I keep getting notification from that camera. The connection strength shows all bars. My internet speed is 500mbps dl and 12mbps ul. Arlo works like **bleep** and the price keeps going up. Wtf right?
Can you remove the Pro 2 from the account and add it back on and see if the behavior you are seeing resolves.
