Camera Recording Only 1 s after Fw Update (1.080.14)
  • 17 Replies
  • 3056 Views
DJArlo
About a week after Arlo pushed Fw 1.080.14 to my Pro 3 camera, it started recording videos no longer than 1 s.  I have restarted the SmartHub, removed the camera battery, reprovisioned the camera, and it still records no more than 1 s when triggered.  It did not do this 48 hr ago.  My other 2 cameras on Fw 1.080.14 are operating OK; they they just updated yesterday, which is when this camera started to have this issue.  Given the Fw update issue I and others have had, I am distrusting this Fw update.
Other than the canned "just remove and re-add the camera" catch-all, any advice?
17 REPLIES 17
I'd do the hardware reset
  1. remove the camera
  2. open the housing and press the sync button until the LED flashes amber (~15 sec)
  3. add the camera back
DJArlo
Thanks for feedback.
(1) Reasoning behind that approach?
(2) I have a dozen modes and some settings involving this camera (used while camera was working properly).  Will these "hardware reset" steps remove the modes and settings?
DJArlo
Per (2),
How do I remove a device from my Arlo account?
"WARNING: Removing a device from your account erases all modes and settings on that device and resets the device to factory default settings."
So I need an alternate solution.
And setting the camera back to the out-of-the-box state is exactly what I am recommending.  Though I prefer the hardware reset (holding down sync) when something is wrong, just to be certain that the camera setup is completely cleared out.
Why is this a problem?  There aren't that many settings, and a subscription (if you have one) will not be affected.
DJArlo
As I posted, I don't want to lose all of my Modes tied to this camera.  Those modes involve other cameras as well.  The Video Settings are dialed in, and it would be a pain, to replace those, too.
Cameras are tied to the modes, not the other way around.  You would need to check the modes.
Though I agree it is a PITA, starting fresh is I think the next thing to try.
DJArlo
I removed via the app, then added via the app.  I did not reset it by holding the sync button (could not get amber lights).  Now the camera records more than 1 s, but it seems it won't record more than 10 s.  No, I don't have a Rule with a 10 s limit.  Since all my custom settings were wiped out, it may take me some time to get back to "normal" and then determine if another remove/reset is needed.
Modes:  I named the camera as it was before, and fortunately the Modes did not get removed, despite what the KB article stated.
How long did you hold down the button?
DJArlo
I depressed the camera sync button (near the charging terminals) for ~15 s.  I tried multiple times.  Only blue light blinking resulted.
Not sure what you mean by "near the charging terminals".  The sync button is inside the camera housing.
DJArlo
...near the charging terminals.
Yes, that is the correct control
DJArlo
Camera still records *mostly* in 10 s segments.  Example:  if motion is there for 40 s, then I get four 10 s recordings.  Sporadically, I get recordings that >10 s.  New abnormal behavior; better than 1 s segments before I removed/added, but unresolved.
ShayneS
@DJArlo
Does the same info for recording length/segments show on the web portal?
DJArlo
No, because at the moment the web portal does not show any recordings.  Only the app is capable of showing local recordings?
Correct.  that is one of many restrictions in direct access to local storage.
ShayneS
@DJArlo
I see, so this is regarding local storage and not cloud storage, Have you tried formatting the drive? May I ask which troubleshooting steps you have tried so far regarding local storage?
  • 17 Replies
  • 3057 Views
