Bug with spotlight function
  • 7 Replies
  • 2256 Views
Gnuts
Hi, I have two Arlo pro 3 cameras and a hub. One of both keeps crashing as soon as it gets dark outside. It seems to be a bug with the night vision/spotlight function. Spotlight Vision should always be on with Color night Vision. Somehow after a reset it starts without the spotlight on. This combination causes the camera to crash (IR and blue lights flashing all night till battery empty).
Gnuts
I have him working again. The cause: misconfiguring the automation. I had created a loop of stand-by and armed. This can cause a camera to stop functioning at the moments of the switch to 'armed'.
7 REPLIES 7
ShayneS
Are you still experiencing this symptom?
May I ask which troubleshooting steps you have tried so far? I don't want to suggest anything you have previously performed.
Gnuts
Thanks.
I tried: complete reset of camera. This ends up with working during daytime. As soon as it gets dark the IR and blue light flash in turn. This drains the battery in 1-2 nights.
The other camera works fine. So I compared all config of both and found differences in spotlight function and color at night. I changed that, recharged an tried the next night. No succes. Will try tomorrow: color off at night, maybe the light is broken. It is strange that as soon as it gets dark the camera cannot be reached. Sunshine? Gets back on!
ShayneS
Have you tried the remove and reinstall the camera?
Gnuts
Yes. No result.
ShayneS
Is this spotlight symptom occurring when live streaming or motion detected?
Gnuts
ShayneS
Thanks for the update!
  • 7 Replies
  • 2256 Views
