Base station VMB4540. Not powering on
  • 4 Replies
  • 1596 Views
LUFC44
Hi , my base station / hub has stopped powering up altogether. I have tried all suggestions on here to try powering up but it appears dead, only 3 years old.... anyone had similar problem if so, is it just case of buying another hub.? I run 3 wireless cameras , nothing else..
It could be the power adapter - it might be worth a risk-buy of a compatible replacement, as that is cheaper than getting a new base.
One of several that claim to be compatible is here:
(Note I haven't purchased this - it is just a starting point, not a recommendation for this specific adapter).
LUFC44
Hi. Thanks SB for your response. I might try that option first.
LUFC44
Hi SB. Just to add I did purchase another power adapter and it worked. Hub powered up and online again. However only one of my 3 cameras have hooked up   I will attempt to pair the 2 in next few days. Thanks for advice as saved many pounds£.
Great.
I hope you get the remaining cameras back on line soon.
  • 4 Replies
  • 1597 Views
