Automatic overwrite is not working
The overwrite feature isn't working. I had to format the usb flash drive to have recordings deleted so it would start recording again. I don't see anything "current" in Arlo Community with this problem. Is anyone else having this problem or any solution to this problem.
thanks
If they were manual recordings they will not be deleted automatically. Have you tried turning the setting on/off and rebooting your base station and test again?
