  • 2 Replies
  • 708 Views
bendare89
Text push notifications work fine on my Android Samsung Galaxy S10E phone. Audible push notifications stop working after a while. I have found that clearing all phone notifications seems to correct issue for a limited time, then I stop receiving them again. Text notifications work fine the entire time. Any thoughts on how to correct so that I can consistently receive audible notifications?
You're mixing things up. Push notifications aren't text messages - they're straight from the app to the phone. The only other notifications are emailed ones. If the push notifications aren't making a sound, that's a phone issue. Try rebooting the phone and reinstalling the app.
bendare89
No. Not mixing things up. I know they are not text messages, but they do show up in text form as Motion Alerts in my notifications. I have other applications that issue an audible alarm without issue. Arlo is the only app I have issue with. I will try reinstalling the app as you suggest. Thanks.
  • 2 Replies
  • 709 Views
