Arlo pro 3 won’t sync
  • 6 Replies
  • 2202 Views
Donkey31
I am having trouble synching my pro 3 cameras to the base unit. I have tried a factory reset but that doesn’t work. Any other suggestions would be most welcome 😀
6 REPLIES 6
What base or hub do you have? Look on the tag on the bottom for VMBxxxx.
ALso, what have you been trying to reset - the base/hub or the cameras?
Matybea
I have a similar problem my base station is vmb4540
And what do you see? What have you tried? Without details we can't help.
Matybea
hola e intentado todo (reset )pero el problema es que no se pueden emparejar con mi estación base tengo 4 camaras pero 2 no se conectan y las demás se conectan sin problema, la cámara de ves en cuando detecta movimiento y aveses deja una imagen como ultimo registro pero cuando quiero ver en vivo no puedo
hello and tried everything (reset) but the problem is that they cannot be paired with my base station I have 4 cameras but 2 do not connect and the others connect without problem, the camera from time to time detects movement and sometimes leaves an image like Last record but when I want to see live I can't
Donkey31
Thank you, all cameras are now connected.
Matybea
Hola no puedo solucionar el problema todavia tengo el mismo problema
Hello I can not solve the problem I still have the same problem
  • 6 Replies
  • 2203 Views
