Hello
I have 2 Arlo 2 with hub in my home. Can I buy the Arlo Pro 3 Add on camera and will it work with the Arlo 2 pro hub?
5 REPLIES 5
Streak2,
I might be misunderstanding something here, so correct me if i'm wrong but to clarify, Arlo Pro 3 will work with an Arlo Pro 2 base (VMB4000/VMB4500) as the KB article you linked indicates.
Quite right James that was an error on my part, the Pro 3 is only not compatible with VMB3500 or VMB3000 .
Great to know , as I have the Arlo Pro 2 with the VMB4000r3 base
Great!
I've updated the solution post above for clarity.
