Arlo pro 3 - cover blowing in the wind activating my camera all the time?
I have a trailer out the front on my driveway with a cover. Is there anyway I can stop it blowing in the wind from activating my camera all the time?
Are you asking about the fixing the cover or the camera? It may be easiest to use straps/bungee cords, etc. to keep the cover tight. If not, reduce the motion sensitivity setting in your modes and rules for the camera until the false triggers minimize while still getting the recordings you need. Testing is needed to determine that setting.
