@Hoathai88 wrote:
Why is 2 of my 4 camera fuzzy in the corners? Like it’s shadows or clouds.
Does this happen all the time, or does it come and go? The pro3 lens is more prone to moisture, since it protrudes more from the face of the camera. It it's moisture-related, then RainX or equivalent can help.
Also, the fisheye lens will create some distortion at the edges. So you might try reducing the field of view, and see if that makes a difference.
Maybe post a video so we can see exactly what you are talking about?
@Hoathai88 wrote:
All the time.
You could swap the cameras around, just to be certain there is no condensation of any kind.
If the problem moves with the cameras, you could contact support and get replacements. https://www.arlo.com/en-us/support/contact.aspx
