Arlo pro 3 I did not receive the motion detections in the apps library
  • 4 Replies
  • 1306 Views
Mosleh
Dear all
I bought arlo Pro 3 system  station and 2 cams, I installed them correctly and they are working fine, I got notified the motion detection events, but they did not appear in the library of the apps.
what is the problem?
thanks
regards
mosleh
Are you in a country where Arlo offers subscriptions? https://kb.arlo.com/000062249/Where-is-Arlo-Smart-available
Mosleh
No Sir 😞
@Mosleh wrote:
No Sir 😞
Unfortunately they don't enable trial subscriptions in those countries either.
Obviously one option is to return the system.
Some folks in your situation have used a VPN to connect to a country where subscriptions are offered.  This would need to be done in your router.
You could also set up direct access to local storage - it's not as functional as cloud storage, but it is a way to see recordings from the app. https://kb.arlo.com/000062337/What-is-Direct-Storage-Access-and-how-do-I-use-it
Lamita
Hi Mosleh,
I am from jordan too and I am about to buy Arlo pro 2 to use it here in Amman, Jordan.
But i am not sure if the Arlo system is compatible in jordan with Orange fiber?
And where from did you buy your Arlo cameras ? Was it from America or from the gulf countries?
I hope to hear from you the soonest possible...shokran
  • 4 Replies
  • 1307 Views
