The Arlo app logs me out sometimes?
When I open the Arlo app sometimes it comes up with the "red log/sign me back in button" which I never log out of the app, I don't know why the app does this. It doesn't do it everytime, when I open the app it goes straight to my library. It happens every now and then and I find it very strange and very annoying.
Does anyone else have the same problem with the arlo app?
I see this once in a while, too. It almost always is a simple re-login without needing to enter details (a few times I have to force close the app so this happens). I believe it also says that the token has expired or something similar so maybe it's a security timeout (or not).
As for automatically going straight to the library, were you looking at the library when you last used the app?
