  • 4 Replies
  • 2093 Views
Mopsu
Is it possible to use alternative wall mounts with the VMA5600 Solar Panel? I would need to be able to tilt the panel 90 degrees to direct it towards the sun.
Anythinng with a 1/4"-20 thread will work. You could also maybe use a block of wood to be able to get the position you need - maybe cut at an angle if needed.
Mopsu
I would certainly think so.
Mopsu
Thanks!
  • 4 Replies
  • 2094 Views
