Arlo Pro3 - Live feed limitations to Homecam IOS App
Looking to use the Homecam IOS/MACOS application that provides live camera feeds via HomeKit integration. I understand the Arlo system (base station limitation?) can only support 2 live simultaneous feeds with this application / configuration (additional feeds only provide lagging snapshots if able to connect). Is there any known updates, configuration changes, or future features coming that would allow all camera feeds (or more than 2) to provide live streaming feeds to other IOS/MACOS applications? Thanks.
You can stream up to 5 cameras connected to a smartHub/Base Station. If you have multiple base stations or smart hubs you can stream up to 15 cameras depending on subscription. You can find more info here: https://kb.arlo.com/1179521/How-many-Arlo-cameras-can-I-view-at-the-same-time
