Arlo Pro Hub Flashing Blue and Orange (VMB-4540)
Arlo Pro Hub Flashing Blue and Orange (WMB-4540). Rebooted, reset, rebabtized, nothing makes it stop. Everything seems to work, just constant annoying flashing.
5 REPLIES 5
It might have been interrupted during a firmware update.
Have you checked this FAQ for clues?
https://kb.arlo.com/000039100/What-do-the-LEDs-on-my-Arlo-SmartHub-or-Base-Station-mean
Is the flashing consistently the same timing or is it more random? That could point to a connection issue with a camera.
It alternates between orange and blue which is not listed on that page. All the cameras are connected and working.
How do I fix it? It says the firmware is up to date.
But what is the timing of the different colors flashing? If it's very even, that points to a failed firmware update. If uneven, it sounds like a connection issue to a camera.
