I have an ARLO PRO 3 system Until recently I was able to access the system and control what was going on with the use of my MACBOOK Arlo did some updates and now it is not possible to use a MACBOOK What a load of crap I now own a useless pile of junk Using the phone app is not useful to me at all
I shall now put the ARLO crap in the garbage and buy something that works
What update are you talking about? 2FA?
Whatever ARLO did about a month ago It used to work, now it is not working and is not supported on the macbook
This is the word I got from an ARLO tech support on the phone
crapola,
When you say it used to work but now is not working. What are you experiencing? Are you seeing any error messages?
