Owned the Pro 3 for about 3 years with no subscriptions. While on vacation lost cameras from arlo app. When I got home I reinstalled. Now no videos are being saved to library although I get motion detection notifications. Would appreciate any suggestions...thx
The pro 3 requires an Arlo Secure subscription to save recordings to the cloud.
Thank you for getting back to me Shane. I was under the impression that a limited number of videos could be saved to the cloud (like videos from 1 camera for a few days). Up until I lost the cameras completely videos were being saved. At any rate, I have the Arlo Base VMB4530r2 and inserted a flash drive but that didn't work but I think that the drive may be the problem although it has been formatted my app says it is "ready". I'm going to buy a new flash drive and see if that helps.
Getting back to needing a subscription, so " nothing" can be save to the cloud without a subscription. Is that correct? If the answer is yes then I will proceed to buy a new flash and install. I'll get back to you if I have a problem....Thx much Wil
That is correct for the Pro 3.
Here is the link to the subscriptions page that has a bit more info regarding the available features per subscription: https://kb.arlo.com/88/What-are-the-available-Arlo-subscription-plans-and-how-much-cloud-recording-i...
I have contacted google wifi to help me set up port forwarding and they informed Arlo would have to let me know what port number or port range I should use in the setup. Also, they said I would need to know if I should use "TCP" or "UDP" protocol... Can you supply me with that info or tell me where I can find that out?...Thx
Hi,
You can find more info regarding the port forwarding here: https://kb.arlo.com/000062337/What-is-Direct-Storage-Access-and-how-do-I-use-it-for-Arlo-video-recor...
