  • 1792 Views
EODK9Trainer
Just received this and cannot figure out how to remedy this.  I bought two cameras for now with the possibility of adding more soon.  I learned on here that I needed an outside source for charging cables that I want to leave attached.  My cameras are sitting on a mantle in the LR and a shelf in the garage.  While sitting on these I cannot leave the after market charging cable on it as of course it plugs into the bottom which is how we have to stand it up.  I do not want to mount  these to the mantle and garage wall and I don't want some large clunky option for the camera but I do need options to keep these charged 24/7.  Anyone have any ideas?
I have used double stick tape on the cameras charger attachment...  it held enough that the Ultra sat on top without falling.
You could do this to any flat heavy object instead of  mounting directly... like a small tile ,etc
( use dental floss to cut the foam tape ( sawing action ) and then remove the tape with goo b gone )
( test first if on special surfaces )
AncientGeek
Hero
Hero
You could mount a small 1/4” 20 articulating mount to a block of hardwood.
https://www.amazon.com/OdiySurveil-Security-Housing-Bracket-Compatible/dp/B00R96X9DS/ref=sr_1_14?key...
Amazon.com  OdiySurveil (TM) Metal CCD Security Housing Wall Mount Bracket for Oculus, Arlo, Arlo Pro and Other Compatible CCTV.png
Similarly you could glue two hardwood blocks into an L shape, and attach the magnetic mount to the vertical piece.  You could also drill a hole into the vertical piece to run the cable through.
  • 1793 Views
