Arlo Pro 3 does work in the Philippines.
  • 1338 Views
Wesofwest
  • Hi! I am a CCTV technician from the Philippines. One of my clients bought an Arlo Pro 3 and plans to install it in her home here in the Philippines. My question is, will it work her?
While the camera can be set up there, cloud recordings won't happen since she wouldn't be able to get a subscription. Since the Pro 3 requires a SmartHub, local recordings can be configured to accomplish this although it's not nearly the same experience.
https://kb.arlo.com/000062249/Where-is-Arlo-Secure-available
https://kb.arlo.com/000062818
Wesofwest
Thank you for your reply, I did setup the for 4 camera smoothly and about the recording, I would use USB flash for that. Now I wonder if I could extend it's AP wireless transmission by adding another AP, is it possible? What is the default password of it's AP by the way?
No.  What you have to do instead is add a second base, and shift some cameras to it.
Arlo hasn't (and won't) publish it.  The wifi network is closed, and can only be used by the cameras.
  • 1339 Views
