I'm having problems with the cloud activity zones. Even though I have the zones set I seem to be getting notifications for motion that occurs outside of them.
Any way to get these working correctly as it's not usable at the moment.
In short, no. Arlo is aware of the problem and say they are working on it. Lots of topics on this if you search the forum.
hi i have noticed these dont work if you have track and zoom on
Thanks,
will give that a try. It'll be a shame if it doesn't work with the track and zoom function on though
Ok make sure you report back 😉👍
