Are there any blacks skins for the Arlo Pro 3 available yet?
I can only find skins for older models.
Hi guys,
We do not sell skins, but instead, high quality case replacements.
The design is the same as on the Ultra camera.
If Arlo has yet to produce skins for your market there are alternatives.
Just another user
Thanks! I found skins on Amazon.
Silicone Case for Arlo Ultra 4K & Arlo Pro 3 (Black 3 pcs) - Ultra HD Series Skins w/Mount Cover - Silicon Sleeves for Arlo Ultra Security Camera - Skins for Arlo Pro3 Cam & Mount Base by Sully
The description says: ” Silicone Case for Arlo Ultra 4K & Arlo Pro 3...”
Good find.
It is hard to find a reason why people should stick to the branded versions for something passive like skins, especially when Arlo is so slow in coming up with its own versions.
Just another user
Hi guys,
@Louis_ArloPM wrote:
Hi guys,
I spotted those but hadn't seen them before.
Nice idea. Do they just swap out for the originals?
Just another user
Yup! just pop the camera part out, and insert into the new case.
