Hi. Prepurchase question... I already have 4 Arlo cameras (3 Pros and the original Arlo). Want to upgrade the camera in the front of the house to the Arlo Pro 3 and swap out the original Arlo. Can I just purchase the new Smart Hub and an add-on Pro 3 Camera rather than buying a 2-Camera Set with Hub?
There is a 1 camera plus base option. You could buy that and add your other cameras to the base.
@tdeprenda On Arlo's website they only have the 2 or 3 cam system with hub (Not sure if they had it in the past) They do have the add on and the hub under options. But as said the other cams will work the hub. You can search for the 1 cam set if someone else has it. A quick search on Amazon U.S didn't show one, just the 2 cam and up.
The Arlo Pro 3 doesn’t crib the Ultra’s next-gen 4K resolution, but it does boost it to 2K, an 80-percent bump from the 1080p Arlo 2. Other features, such as customizable motion zones and a multi-mode arming system.
wanna add something
The Arlo Pro 3 introduces a new SmartHub base station. At first glance, it doesn’t look much different from the one that accompanied the Ultra, but it replaces the original SmartHub’s microSD slot with a USB port, and supports up to 2TB of local storage, so you don’t need to depend on the cloud.
