Arlo Pro 3 - adding another camera but with higher definition.
  • 1 Reply
  • 1201 Views
PamelaNZ
I have an Arlo Pro 3 system and am toying the idea of upgrading one camera on my street frontage to a model with higher definition.  Does anyone know if this is possible (or would I need to upgrade the whole system)?  Thanks.
You can add an Ultra or Ultra 2 camera (which supports 4K).  You'd also need to upgrade your subscription to Arlo Secure Plus, since Arlo Secure only support 2K.
FWIW, given the low bitrates Arlo uses, I personally don't see all that much difference between their 2K and 4K recordings.  Though the Ultras also have a wider field of view, which is often useful.  And if you zoom the camera, then the Ultras will lose less resolution when you zoom in.
  • 1 Reply
  • 1202 Views
