Arlo Pro 3, SmartHub issue, amber led flashes
  • 7 Replies
  • 2466 Views
OstapStad
Hello! I bought my Arlo Pro 3 bundle a few months ago in US. Now I live in Ukraine and I am trying to install it in my house. I haven't used it before. When I try to connect my SmartHub it connects to the Internet, but in a minute it starts flashing amber light(error). Is it because of I am in Ukraine? I tried resetting, pressing "sync" button on cams and SmartHub and a lot of other stuff. When I install USB stick it creates a folder named "Arlo" Idk what to do....
7 REPLIES 7
How do you know it's connected to the internet? Does the router show an IP address being assigned to the hub? When trying to reset, did you hold the button for >15 seconds until the LED started flashing amber? From a computer can you ping arlo.com (from a command window type "ping arlo.com")?
OstapStad
Yes, I can ping arlo.com. LED is blue for around 2 minutes after power up(amber, then becomes blue). Yes, IP address is assigned. While resetting, LED starts blinking with amber, as you said
Is the base showing an off-line status in my.arlo.com?
I'm wondering if the issue is the base itself, or whether it is the cameras not connecting with the base.
OstapStad
I can't check the SmartHub status, because of the issue. I can't even add hub to my account. App can't find any device.
If you are trying to add it with your phone, then try adding it from a PC browser using my.arlo.com
OstapStad
I just tried to add my SmartHub from a laptop and it says "no devices found" or smth just like this.
OstapStad
There's a strange thing. Even if I disconnect Ethernet it shows the same LED behavior. Amber(~1 min), then blue(~1 min) and then amber error blinking
  • 7 Replies
  • 2467 Views
